Great news regarding Pedal Power compatibility
Thanks to some last minute tweaks, we were able to get the power consumption down to 400mA @ 12VDC. This allows you to run the PBC from Pedal Powers that have a 12VDC 400mA output. I've been running one from a Pedal Power Digital for the past 48 hours and it's still working well. We will also test the other Pedal Power models, but I'd expect that any of them that have the same 12V/400mA output should work fine.
So does this mean it won´t work on 9 volt like the specs say ??( I have bought a gig rig power solution to use with the PBC :-(..................
From the FAQ:
"What are the power requirements?
The Mastermind PBC will run on 9VAC, 9VDC or 12VDC. The current consumption at 9VDC is about 500mA, but the current consumption at 12VDC is 400mA."
Great news indeed. I have 12vDC outputs on my Cioks Powerfactor 2 power supply, so hopefully those will also work!
I'm also using the PBC with a Ciokolate and the 400mA/12VDC output works fine. I'd imagine the other Cioks supplies with similar outputs should work as well.
