Julien
Hello
I moved some stuff around on the board, and I'm trying to achieve the following. I'm pretty sure this is going to be an easy one for you!
PBC/6X, latest firmware.
Loop 1 : Pedal A
Loop 2 : Pedal B
When I switch on Pedal A, I want the pedal B to be off, and when I go to pedal B, I want pedal A to turn off.
For this, I put them both in the same group, which works.
No here's the next "step" I'd like to add, that I can't figure out (yet):
To the above, I'd like to also be able to turn them both individually if needed.
Right now it's either one or the other, which is great, because I don't stack them.
But I'd like to also be able to turn them off, should I decide to use other pedals in the other loops that don't necessary work well with these.
I hope this makes sense.
Also, on another note, I noticed that buttons that contains HOLD functions, seem to cause slight delays when switching presets:
e.g:
Preset 1: loop 1 with Distortion A
Preset 2: loop 2 with Distortion B
Switching between preset 1 and 2 is instant
Preset 3: loop 3 with Distortion C (turned on by an HOLD button)
Switching to preset 3 has a slight delay in turning on Loop 3
Is it normal?
Back to brainstorming!
Thanks for any (stereo) input you may have!
Regards,
Julien
Loop 1 : Pedal A
Loop 2 : Pedal B
e.g:
Is it normal?
Regards,
Julien
