Hi Ron
I'm considering setting up a Hot Hand 3 (http://www.sourceaudio.net/products/hot ... thand3.php) with the GT via one of the expression pedals inputs. I'm sure that this will work fine as the Hot Hand can essentially be treated as an expression pedal.
However, is it possible to do the following with the GT?
..In addition to controlling fx with the Hot Hand, can the GT be setup so that whenever it senses movement from the HH it also sends several CC messages to the Effect Gizmo to switch on/off certain Gizmo Loops? If possible, i'm assuming this would involve setting an "auto engage" style threshold (similar to the parameter available on the Axe Fx II itself for example).
