GT10 Power Supply
cuterigs
Hello!
I'm building a rig for a client that uses the MM GT10. I was wondering if this power supply on Amazon meets the specs to power the GT10? It's 12v, 3A, 2.1mm Center Positive. The board is pretty packed so I was wondering if this smaller option would work before we order the official RJM supply from the shop.
12V 3A Power Supply
Thanks so much for any help!
jg
That seems like it should be fine, it's the same basic specs as our power supplies. The only thing you might run into is noise - some power supplies are noisier than others. Since no audio goes through the GT itself, the supply has to be pretty darn noisy, or very close to your audio, to cause a problem.
Thanks so much!
