Johannes Egger
Hey
I want to build a Rack-Setup with some analog pedals and an Axe Fx, but I just cannot figure out the perfect routing on the Effect Gizmo :/
The whole Setup is going to be used in conjunction with a Friedman SmallBox50 head.
Pedals in front of the PreAmp:
- Boss OD3
- TRex MH II
- Suhr Riot
- OBNE "The Haunt" (Fuzz)
Pedals in the Fx Loop of the Amp
- Strymon "Big Sky"
The Axe Fx should be wired using the 4CM, since I´d also like to use the 2CH of the SmallBox (Ch-Switching via EG as well)
Is this whole wiring even possible!?
May I also use the Buffer-IN / CS-circuit or should I stick with the "normal" ones?
Thank you for your help in advance.
- Boss OD3
- TRex MH II
- Suhr Riot
- Strymon "Big Sky"
