Gear: Mesa Mark V ,Digitech GSP 1101(processor),Maxon OD,Crybaby Wah.Geetar
Ok I know I'll go Guitar into Wah.
Normally the the guitar plugs into the GSP front panel input. GSP send goes into amp input. A line out goes to amps loop return. Amps loop send to GSP loop return. This allows you to use pre-amp stompbox and post-amp effects from the GSP.
Midi will be changing the amps 3 channels via foot controller - GSP midi to Rack Gizmo.
I want the Maxon OD to go off and on as programmed into midi.
GSP foot controller will be the midi controller.
I'm reading that you do not want and OD to go into the buffer.
I'm also interseted in using the click stop.
I would be greatful for some help here. Thanks. --SP
