help with connection
hi , well i have a lot of racks and pedals and now with my rg-16 i don´t know how connect it =(
i say you what can i have
* RG-16
* DECIMATOR PRORACKG (rack format)
* DCR-2SR CRY BABY RACK
* MXR PHASER 90
* MXR OVERDRIVE ZAKK WYLDE
* EVENTIDE PITCHFACTOR
* TC ELECTRONIC 2290
* MARK V
* DUAL RECTIFIER CABINET
thanks and...please help me =)
i follow the diagrams but with decimator prorackG i don´t know where connect it.
can you tell me all =)
Here's one way to do it (see attachment)...
  • RG-16_4Pdl-2Mono-Deci.pdf
ron, why did you patch the signal from loop 7 to loop 8?
just to be able to add an other effect later on?
Ah yes, I forgot to mention. The stated configuration wouldn't need loops 4 or 8, but you can plug something into them if more effects are needed. Loops 7&8 don't need to be jumpered like that unless you want to use loop 8, output 7 could go to the amp's return instead.
hi =) at first i say thanks ´cause the wiring diagrams that you did it it´s perfect except ´cause it has a problem with the third audio loop my overdrive not sound in that audio loop i´m putting in the fourth audio loop and well but my question is why doesn´t well ?¿?¿?
thanks again
The first thing to check is your power supply. If it's 9VDC and not 9VAC or 12VDC, you will have some loops that don't work.
I meant the transformer for the RG-16 - if that's not the right kind, you will get some loops working, and some loops not working.
