Dimitri Papadimitriou
I'm using PBC6X via midi to control HX stomp blocks, etc... I have a preset I want to access on the HX Stomp as PC#28.
I also have two blocks in that HX preset assigned as IA buttons on the FNSw 1 and 2 slots on the switches page (instead of using a cable and two button aux switch). It's been working fine until today when I wanted to start building new presets.
I tried to program my first 4 PBC presets as dirt (1), dirt with boost (2), clean (3), clean with boost (4). I set everything up the same by copying and pasting everything. Everything is right except those two blocks that are IA buttons.
When I clean on preset 1, the two blocks on HX are off. Then on preset 2, they're both on. On preset 3 both off, and on preset 4 both on. I went in manually and turned off the blocks on the HX, resaved the HX preset and PBC6X preset... and then when I go to the next preset, those two blocks are either on or off. So obviously there's some sort of conflict with those two buttons and blocks.
I tried turning off send on preset change. That kept the two blocks activated on all 4 presets. When I turned it back on, the blocks were on when preset 1 and 3 were activated. It's like its alternating.
Can anyone guide me on what to look for. I haven't messed with the PBC in a long time and now I'm stumped again.
