Hx Stomp and PBC/6x
mauroxcastro
Hi! I have a question about wiring my pbc/6x with my hx stomp and need some help!
I use my Hx Stomp as an amp modeler and some effects. I know that the Hx Stomp have fx loop stereo, so I was wondering if I can do a double 4 cable method?
I want to use for example, FX Loop L as first on my signal chain, before the amp modeler and use the FX Loop R after the amp modeler. I know that I have to use the blocks in the Hx Stomp.
My question is if I can use the insert loop split from the PBC/6x, and connect there the FX Loop L and R.
The signal chain is:
Guitar In -> IN PBC
PBC Loop 1 -> Seymour Duncan 805
PBC Loop 2 -> Bondi Effects Sick As
PBC Loop 3 -> Zvex Distortron
PBC Loop 4 (split) -> Jhs Emperor
PBC Loop 5 (stereo) -> Strymon Timeline
PBC Loop 6 -> Walrus Audio Lore
PBC Loop 7 (split) -> Death by Audio Space Bender
PBC Insert Loop Send L (split) -> Input L Hx Stomp
PBC Insert Loop Send L (split) -> Input R Hx Stomp
Send L Hx Stomp -> Insert Loop Return L PBC
Send R Hx Stomp -> Instert Loop Return R PBC
PBC Out A -> Return L Hx Stomp
PBC Out 2 -> Return R Hx Stomp
I will use the PBC's loop reordering to place this two Loops where I want before and after the amp from the Hx Stomp.
I don't know if this is right. Is it possible?
I know that it will work on the PBC/6X. However, it will also depend on the HX Stomp- if it also can split its FX loop into two separate loops, then your idea should work. If it doesn't support splitting its FX loop, then you would be limited to using the insert loop and FX loop as a single stereo loop.
