neilvg
I have a looper pedal that I engage on or off (the Microcosm) through an IA button - on a loop.
Generally I want this off on each preset by default, since the pedal does a bunch of other things, but sometimes I just want to use it as a looper.
So I may have a loop going, but if I change Presets (not IA loops on off but Presets themselves), this pedal:
- gets sent midi info, and stops playing the loop
- the IA loop gets turned off because the preset is saved without it
How do I get its so this loop acts like an ON or OFF persistence even through preset change even if the preset does not have it on in its saved setting? So that I can change tones and not have it influence the loop? I get that if I have a preset that sends specific MIDI information to this pedal, that it can still change that if I want, but for just guitar tone preset changes, I'd like this loop to continue to be on unless I turn it off, in which case I want it continued to be off.
hope I cam being clear enough!
Thanks
Thanks
