ChrisConteGuitar
Hi Ron, I recently added the Source Audio EQ2 pedal as a boost. I assigned it an IA button and I send a CC number to toggle on/off via MIDI. It works find when engaging the IA button. However, when I assign the IA button to a preset, the IA button appears to "turn on" (color changes), but it will not send a midi command to turn on the pedal. I use a midi monitor and I can clearly see it is not sending the midi cammend to turn on the boost pedal. Is there another setting I need to set?
