cuterigs
hey all!
I'm setting up a rig with a PBC6X and an HX Stomp. Editor and PBC are on 5.1. They want to be able to turn blocks on/off from a page on the PBC and hold FUNCTION (Page up/IA Store) to be able to make presets on the PBC on the fly.
I started setting things up like @rjmmusic has suggested: set up a page with buttons assigned to each block on the Stomp.
The buttons change the status of the block. All good.
What doesn't work is IA store.
He can turn the button on for any block in editor's Preset page, write changes to device, and as he goes through presets on the PBC and stomp, coming back to PBC preset 1/HX stomp preset 17 will call up the proper blocks.
If he goes to PBC Preset 3/HX Stomp preset 17, goes to his HX page and turns on blocks as needed, the blocks change as needed. if he holds IA Store, it doesn't save the block status. it says on the screen "IA Store" but coming back to PBC preset 3/HX preset 17 will come back with all blocks off (this is how the HX preset is stored, he wants to call up different combinations as needed from a single HX preset so that he doesn't lose delay/reverb tails by changing PC's).
If he turns on the buttons on his HX page via editor on the Presets tab, it works as intended.
Why is the behavior different? the PageUp/IA store button was copied from the stock Loops page on the PBC.
Any help would be great! thank you! (RJM file attached... his presets/block buttons aren't fully setup yet, it's all in progress)
PS I tried searching for something like "IA Store doesn't save" but apparently "IA" is too small of a phrase to search for, so it seems impossible to search for anything related to IA, unless I'm doing something wrong? any tips for that would be helpful too! thanks so much everyone!
