Insert loop disappears when overriding global loop order
Jamm0r
Any idea why my insert loop is gone when I click on the override button for loop order within a preset? The insert is on and locked in the global audio tab. Within the preset that I’m editing, the insert says on and is grayed out, I assume because it’s locked in the global tab. However, the insert loop is not in the presets loop order and is not on. What’s also weird is if I unselect override next to loop order, the insert is back but loop 6 is gone.
Are you using the latest firmware and editor? (5.0.1)
Also, if you do the same on a preset that you haven't edited yet, are all the loops present? If so, copy that preset over the one(s) that have a problem and that should fix it.
Yes, I’m using the latest firmware and editor.
The behavior is the same for any preset, including one that has never been edited.
It does go away. I have a lot of time into my current settings though (presets, songs, devices, global settings, etc.). Don’t want to start from scratch.
Please send me your settings file and I'll have a look at it.
In case anyone else runs into this issue, Ron came up with a great workaround. Worked like a charm for me. Thanks again Ron!
- Load up your settings in the editor
- In the Global tab, set Model to LT/7
- When it asks you if you want to restore default settings, answer No
- In the Global tab, set Model to PBC/6X
- Save this as a new file (don't overwrite your old one, just in case!)
