Chris@KatsuKuriMedia
I hooked up my Infinity Looper and added it to my Axe-Fx II using the Axe's MIDI Thru function. Setup Device 2 on the MMGT to the Infinity Looper and assigned some buttons. Everything works great!
The Looper has a particular mode where it will play till the end of the recorded loop before switching to the next loop or stoping - they call this "trails." So I record Loop 1, then play it. When I press stop in the middle of the loop, it doesn't stop immediately, it plays the loop and at the very end, then it stops. Same for switching to Loop 2. This is a great function for a live performer, so you don't have to hit the buttons exactly when you need the loops to come in.
However, since the Stop doesn't work immediately but waits till the loop is done, if you DO want to stop immediately, you must press the Stop button 2x. this works, but sometimes it's difficult to time a 2x stop (aside: all the single button loopers use this 2x press for stop, it's hard!).
I tried putting the Stop Action in an IA switch to get this 2x press, but it seems the messages go very quickly and the Looper doesn't recognize it as 2 presses. I don't see any Pause command though. Is there a way to do this?
There is definitely no MIDI command for this function. The only way is to press Stop 2x. I'd love to do that with just one press of the button on the MMGT. Thanks.
