Iridium / Gizmo x users
Big Lid
How do you have it set up? Do you have the Iridium in a loop or do you have it after the gizmo (gizmo into iridium into amp / board)
I'm currently using a dual amp set up at home and would like to use the iridium direct into the amp w/o a cab.
When playing live I want to run direct into the board from the iridium
If you're going to be running the Iridium 100% of the time, and you want the Iridium last in the signal chain, it would make sense to just put it after the MEGX. No need to use up a loop.
