FriedOutKombi
Hi, I've recently bought an LA Lady Overdrive because it was midi controllable and because of the huge number of distortion engines on it. Plus, it's stereo! I'm not using the Neuro Hub with it, instead using the new SA-168 Midi Adapter. It only has 6 presets but having hooked everything up as per the manual (like set the midi channel on 1 as it apparently likes that). I can't get the 6X to switch between the 6 presets. Momentarily I get it to work, then it stops. Now and again it works for a millisecond then stops. This is the set up I have in the devices menu (as it's not listed in the Source Audio devices) and I'm using PC changes 1 thru 6.
Is there something I need to change? Have I done something wrong?
Thanks
Thanks
