Kemper Morph
R_Faber
Hello new member here, I am using the Mastermind GT with my Kemper, is there a way to have a preset send a second cc command on the second step of the preset? I know IA buttons can do this, but I can't get a preset to work in this way. Kemper has an morph mode on the second step and I was hoping this is possible to do with the Mastermind
Yes, set Preset 2nd Press to IA in Global settings. Then, assign each preset button to control the Morph function. The button should have Send on Preset change turned off and Update on Preset Change turned on for best results.
Perfect that worked!
Only thing is that it if you switch to another preset from the 2nd press it doesn't always switch reliably.
But it does seem to switch reliably if you step on the original preset again (Morph Off) before switching to a another preset, so just something to keep in mind when I am using this function
Thanks
You could try turning on Send on Preset Change on those preset buttons. It might help (I'm not certain about that but it's worth a try).
