So it doesn't work in reverse, even though it's bidirectional?... the Din5 side would go in the Mastermind and the USB side in the kemper...You would need a USB Host adapter to connect it. A normal MIDI interface like the one you show above only works for devices that have standard MIDI ports.
It depends on whether the Kemper itself has USB MIDI host support. I don't know if it does, or if the USB A port is only for a thumb drive.So it doesn't work in reverse, even though it's bidirectional?... the Din5 side would go in the Mastermind and the USB side in the kemper...
According to the kemper player manual it works... or am I wrong? In this way, would it be possible to control the Midi via Mastermind LT with the specified cable?It depends on whether the Kemper itself has USB MIDI host support. I don't know if it does, or if the USB A port is only for a thumb drive.
