Terry Richalds
Having trouble getting a stereo path correctly with my HX Stomp and Mastermind PBC/10.
Here's how it's routed (diagram pictured)
Guitar >>
PBC In 1-4
PBC Out 5-6 >>
HX Stomp In >>
HX Stomp Amp and Cab Sims >>
HX Stomp FX Loop Block (TRS Send) >>
PBC In 7-10 (Button Pressed IN) >>
PBC Out L&R >>
HX Stomp FX Loop Block (Return) >>
HX Stomp Out L&R >>
FOH
There seems to be an issue when I use a TRS cable from the HX Stomp Stereo SEND to the PBC IN 7-10 Jack. Ron instructed me to press the Mono -> Stereo (out) button to the "IN" position to maintain the stereo signal coming in. It seems that I'm only getting the left side however. When I press the button to the "OUT" position I hear both sides but in what I perceive as dual mono. My Left and Right amps inherently sound very different so I can tell something is wrong.
I've tried several TRS cables from the Stomp SEND to the PBC In 7-10 with the same result.
I've attached a diagram of how I have my board wired up as well as my .rjs file.
HELP!!!!!!! Thank you!
Guitar >>
PBC In 1-4
PBC Out 5-6 >>
HX Stomp In >>
PBC Out L&R >>
HX Stomp Out L&R >>
FOH
