CaliCaveman
I just put the Line6 DL4 MII on the board and can confirm a weird behavior between the unit and the RJM.
I've tried different midi cables to test and consistently over a period of 5-10 minutes, when the RJM midi out is going to the midi in of the DL4, at some point the DL4 goes into a some kind of loop sound like machine gun but really fast and electronic sounding of course. I can repeat the issue consistently. If I leave the midi cables unplugged from the unit the issue does not happen at all. So, it seems I'm dealing with a buggy midi issue on the unit, or is there some setting I should be careful with for line6 stuff or how I added the device? I just used generic device setup on midi channel 1 for it. All the CC commands and PC changes seem to work just fine. I'm thinking maybe the midi clock or something, but if anyone has anything I should try setting wise, that would be great. I haven't seen an issue like this before, but it's a new unit just released, so it's very possible it needs an update already or something....
Thanks.
Thanks.
