Charlie
I am running a Damp/Dry Rig and when I change to channel 2 on my Damp amp (both wet and dry signal combined) with an IA button using the Action “Audio/FnSwitch ” my amp inverts the phase thus becoming out of phase with the dry amp.
Is it possible to link the Audio/FnSwitch to the Audio/Invert B Buttons so every time I switch to channel 2 on my amp the phase in output B is automatically inverted?
Conversely, I also run a rig where the dry amp is naturally out of phase with the damp amp.
Therefore, I need to Invert output B when not channel switching and have a Normal output B when switching to channel 2.
I have had no luck with a solution, I was also hoping to be able to just change the on/off values of an Action to adjust for both set ups.
Thank you for any help.
