Hey guys! I’m having a new problem I haven’t seen before. I have drive pedals set up in Loops 2 - 5. This morning, loops 2 & 4 just stopped working when activated.
At first, I thought it was a cable issue, but it is not. If Loop 2 is active but the pedal is turned off, it’s like a true bypass and volume is normal. The moment the pedal is turned on, the volume either cuts completely or sounds really far away. Loop 4 has the same problem.
Here is the strange thing... if Loop 3 is active and THEN you turn on Loop 2, they stack and Loop 2 works. The moment Loop 3 is turned off, Loop 2 stops working again. Loops 5 & 4 have the same relationship. If Loops 5 is on, then Loop 4 will work.
Nothing has changed with my rig.
Please let me know if anyone has run in to this or has a solution!
