Andrealoud
Howdy!
I have an LT and the display doesn't seem to be working properly. Setup is as follows:
MM USB out to Mac Powerbook USB In
MM MIdi out to MEG Midi In
MEG powered via Voodoo Labs PP2 output #5
The screen on the LT is blank. I've also tried plugging both the LT and MEG directly into power (not using the VL PP2) and the screen is still blank. Tried powering by plugging into a USB hub connected to the powerbook, and plugging directly into a powerbook USB port. The light is on, but no visible text. The button lights on the LT and MEG work just fine - only the display is empty. Tried a factory reset but there's nothing in the display...
Can you help?
a
Can you help?
a
