Hello,
The manual says the LT takes either 9V or 12V DC power, but the information in the forum say 9 or 12V, but does not specify AC or DC. I know other pedals you make can take either AC or DC power. Can the Mastermind LT take either AC or DC, or must it be powered only by DC?
I have a second rack that has an RG-16, which takes either 9V AC or 12 V DC, and I want to phantom power the LT from the RG-16. Currently, the RG-16 is receiving power from CIOKS unit that has an AC output. Unfortunately, the only 12V DC power supply I have available only supplies 400mA, which is not enough to supply both the RG-16 and the LT.
Would your Phantom Power Adapter - DIN7F (one input) work in this situation? I want to connect the LT to phantom power adapter, and then connect the RG-16 to the 5-pin midi input. I am assuming that the adapter will send power to the LT, but also pass midi commands from the LT to the RG-16. Is this correct?
