gregg1ep00
Preset tab
There should be a way to initialize multiple presets at the same time. From an implementation standpoint, I think the easiest way would be to allow the "Copy From" context menu item if more than one preset is selected. The idea is, I could create a special "Initialization Preset" that would serve as my baseline. I could define Tempo="Song", preset actions, etc., just like a normal preset, and then highlight whichever presets I want to affect, right-click / Copy From, then select my initialization preset.
Songs tab
There should be a way to clear or delete multiple songs.
Setlists tab
There should be a way to clear or delete multiple setlists.
Audio tab
It would be really cool if we could create aliases for loops and devices, almost like an abstraction layer on top of the physical loops. Button pages and presets would reference the alias rather than the physical loop. This way, if you do a rewire or reconfiguration, you don't have to go back and change all your presets -- you just change the aliases and you're done. Kinda like a device map -- "Pedal A is plugged into PBC Loop 1", "Pedal B is plugged into Effect Gizmo Loop 7", etc.
Songs tab
Setlists tab
Audio tab
