Mastermind GT firmware and editor version 4.3 is now available!
FEATURES:
TO UPDATE FIRMWARE:
- First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your GT will factory reset.
Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT430.zip
Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.3.0.dmg
PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.3.0.zip
Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.3.pdf
Editor Manual (not updated for 4.3 yet): http://www.rjmmusic.com/wiki
FEATURES:
- Support for Meris pedals, Chase Bliss Dark World, Line 6 Helix LT, HX Effects and HX Stomp
- New action: System / Set IA. This one allows one IA button turn another on or off. IA buttons now have an IA ID number, and Set IA uses that to determine which IAs to turn on or off. This is one of those features where it can be really helpful or can cause trouble depending on how you try to use it. With great power comes great responsibility! At least, the system will prevent improperly configured Set IAs from causing an infinite loop, so you shouldn't be able to hang the system.
- Improved handling of preset and scene changes in the Axe-Fx III when Poll State is turned on. It's now much smarter about figuring out when it should change presets and when it shouldn't.
- Added Copy To and Copy From options in the song and setlist screens of the editor. You can access these by right-clicking (or Ctrl-click on a Mac) on the song or setlist in the left column.
- Fixed a nasty bug that made a row of buttons get stuck in the bootloader screen
- Fixed a problem with grouped IA buttons when using 2 or more GTs in remote mode.
- Fixed a bug that prevented the Kemper tuner from being visible when using it in slave mode
- Fix copying of local pages in the editor, cycle data is now copied correctly
- The Set IA action now works with grouped IA buttons
- The Set IA action has two new special values: "Next" and "Prev". This allows you to change a button to its next or previous state instead of specifying a specific state. When used to change a normal IA button, both Next and Prev do the same thing - they toggle the button. When used to change an IA Cycle button, Next will move forward one step, Prev will move backwards one step.
TO UPDATE FIRMWARE:
