Firmware 5.2.1 & editor version 5.2.0 are now available!
FEATURES:
Version 5.2.1 includes the following fix:
TO UPDATE FIRMWARE:
-OR-
Firmware: https://www.rjmmusic.com/download-content/MMGT/MMGT521.zip
Mac Editor: https://www.rjmmusic.com/download-content/MMGT/MMGTEditor-5.2.0.dmg
PC Editor: https://www.rjmmusic.com/download-content/MMGT/MMGTEditor-5.2.0.zip
Manual: https://www.rjmmusic.com/download-content/MMGT/Mastermind GT Manual-4.3.pdf
FEATURES:
- New device support:
- Chase Bliss Bliss Factory and Reverse Mode C
- Electro-Harmonix 8 Step
- Hologram Microcosm
- Kemper Profiler update: add looper controls
- Line 6 HX One
- Meris Mercury X
- RJM Music Full English
- Added "Use Song Index" MIDI setting, which controls whether an incoming MIDI bank number selects a song by its number, or whether it selects by index (1st song in the setlist, 2nd song in the setlist, etc.)
- Added "Clock Pulse Limit" MIDI setting, which causes the Mastermind to send only a specific number of MIDI clock pulses each time the tempo changes. This makes it work effectively like tap tempo, just much faster. Setting this to 0 keeps the default behavior (continuously send clock pulses).
- Added special value "Preset" to the System / Page action. This shows the button page indicated by the currently loaded preset.
- Added special value "Preset" to the PC action. This sends the PC stored in the current preset for the selected device.
- Fixed a bug that caused external switches on pages 2 and higher from properly switching audio features
- Fixed a bug that caused the LEDs not to update when dismissing the tuner screen
- Fixed issues in the setup menus relating to the "clear" button
- Fixed a bug in the PC Edit menu that caused it to not calculate presets and banks correctly
- Fixed a bug in the System / Page "preset" special value
TO UPDATE FIRMWARE:
-OR-
