Firmware and editor 4.8.0 are now available.
Now updated to 4.8.1, see below...
...but... Windows editor has been updated to 4.8.2, see below...
FEATURES:
- First, back up your settings to a flash drive or computer! If you go back to 4.7 or earlier, your GT will factory reset.
Firmware: https://www.rjmmusic.com/downloads/MMGT/MMGT481.zip
Mac Editor: https://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.8.1.dmg
PC Editor: https://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.8.2.zip
Manual: https://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.3.pdf
FEATURES:
- New device support:
- Ampete switchers
- Boss RE-202
- Eventide Blackhole, Micropitch, Tricerachorus, Ultratap
- Jackson Optimist
- Line 6 DM4 II
- Morningstar ML5
- Neunaber Illumine
- Synergy Syn2
- Walrus M1
- Fixed Mini Effect Gizmo X CC list
- Fixed IA Cycle synchronization in remote mode
- Fixed Copy Preset on GT/10
- Fixed a bug that cause Auto Tap to trigger when switching to BPM=off
- Added Off Color for presets, so that you can now specify an on color and a off color to be displayed on the preset's button
- Added System / Setlist special value Reload, which brings you to the first song, first preset in the current setlist
- Axe-Fx III/FM3/FM9 now disable looper buttons when there's no looper available in the current preset
- Editor: fixed weird behavior at the end of the song and setlist lists
- Fixed the missing Illumine pedal data
- Fixed Assign Default Buttons for Syn2
- Fixed firmware update bug in 4.8.0 editor
- Fixed version number displayed in editor when converting older settings
- Fixed Set IA action "prev" and "next" special values
- Fixed remote mode synchronization of grouped IA buttons
- Fixed an issue in the Windows editor where it wouldn't read from the GT
