Ron Forrest
Hi,
I picked a GT22 and having fits trying to get the RJM Effects Gizmo to remotely switch the drive/boost off and on. My Setup is as follows:
RJM Effects Gizmo V1: Midi Channel 2: Loops 9 -12 set momentary:
GCX Switcher Midi Ch 16
Mini Amp Gizmo Midi Ch 3
Y-Not Midi Ch 4
Everything other than the remote switching is working. Effects Gizmo Loops 1-8 turn off and on correctly I'm able to control the GCX without any problem, The Mini Amp Gizmo and Y-Not work correctly with both PC and CC commands. The strange thing is that on the Effects Gizmo i can manually press loops 9-12 and the pedals will remotely switch without a problem. If I assign them to a IA, Macro Preset the lights on the Effects Gizmo will turn on but will not remotely switch the pedals. This all worked when i add my MFC-101 connected to it so its got to be something I'm not programming correctly.
Y-Not Midi Ch 4
