MASTERMIND LT 5.1.0 FIRMWARE / EDITOR
Status
Not open for further replies.
rjmmusic
Administrator
Staff member
Firmware & editor version 5.1.0 are now available!
FEATURES:
  • New device support:
    • Amplitube Tonex
    • Chase Bliss Mood 2 & Gen Loss 2
    • Flower Sunflower
    • Strymon Brig, Cloudburst and Ultraviolet
  • Added new Bank Size parameter, which allows you to set a fixed bank size. This is the amount of presets the Bank Up and Bank Down advance through the preset list. (This has no effect in Song & Setlist mode.) The default value "Auto" is the old behavior, where bank size is determined by the number of preset buttons on the current page.
BUG FIXES:
  • Corrected the default settings for the Axe-Fx III looper button
  • Improved the way log taper compensation works in expression pedals, expression pedal bar graph also works better when using log compensation
  • Fixed issues in the setup menus relating to the "clear" button
You can also read the full change log if you like.
TO UPDATE FIRMWARE:
-OR-
Firmware: https://www.rjmmusic.com/downloads/PBC/MM510.zip
Mac Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-5.1.0.dmg
PC Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-5.1.0.zip
Manual: https://www.rjmmusic.com/downloads/MMLT/Mastermind LT Manual-4.2.pdf
Status
