EVHGuy1111
Hello,
Still building my Ultimate Guitar Rig. It's coming along nicely. RJM makes ALL THE DIFFERENCE when working with MIDI controllers and analog stompboxes. I love being a part of the RJM family.
I've been investigating the best way to control the expression functions on 4 of my stompboxes with 1 expression pedal. I require this because I have a small foot board with room only for an Expression Pedal (DUNLOP Volume X 8), a wah (DUNLOP CryBaby Jr) and the MASTERMIND LT. Everything else in my rig is on the backline and I would prefer to keep it this way for the purposes of a small footprint on stage.
The best I can figure out is to run the expression pedal to the expression jack on the MASTERMIND LT. Then from there I need a MIDI to 1/4" box with 4 outputs (or several MIDI to 1/4" boxes as needed to facilitate the number of pedals I want to control). Then I just tell MIDI to include the Expression Pedal (via the MIDI to 1/4" box) on presets as I create them for the relevant stompboxes that require expression pedals.
I found this Empress Effects MIDIBox 2 in my research. It seems this is what I want to do the trick (I also have found a video how to modify this MIDIBox for when not using in conjunction with Empress pedals -- which I won't be and then likely will have to modify).
MY QUESTION:
Am I on the right track and will this MIDIbox work (if not, does anyone have any idea what might)?
Thank you.
RJM FOR LIFE!
MY QUESTION:
Thank you.
RJM FOR LIFE!
