Firmware and editor 4.8.0 are now available.
Now updated to 4.8.1, see below...
FEATURES:
-OR-
- Use the Transfer / Update Firmware menu option to update the Mastermind. This works with the PBC/6X and PBC/10s made after March 2019.
Firmware: https://www.rjmmusic.com/downloads/PBC/MM481.zip
Mac Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.8.1.dmg
PC Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.8.1.zip
PBC/6X Manual: https://www.rjmmusic.com/downloads/PBC6X/PBC6X Manual-4.3.pdf
PBC/10 Manual: https://www.rjmmusic.com/downloads/PBC/PBC Manual-4.2.pdf
FEATURES:
- New device support:
- Ampete switchers
- Boss RE-202
- Eventide Blackhole, Micropitch, Tricerachorus, Ultratap
- Jackson Optimist
- Line 6 DM4 II
- Morningstar ML5
- Neunaber Illumine
- Synergy Syn2
- Walrus M1
- Fixed Mini Effect Gizmo X CC list
- Fixed IA Cycle synchronization in remote mode
- Fixed a bug that cause Auto Tap to trigger when switching to BPM=off
- Added Off Color for presets, so that you can now specify an on color and a off color to be displayed on the preset's button
- Added System / Setlist special value Reload, which brings you to the first song, first preset in the current setlist
- Axe-Fx III/FM3/FM9 now disable looper buttons when there's no looper available in the current preset
- Added "Show Preset Number" parameter, which allows you to switch of display of preset number in the main display
- Editor: fixed weird behavior at the end of the song and setlist lists
- Fixed the missing Illumine pedal data
- Fixed firmware update bug in 4.8.0 editor
- Fixed version number displayed in editor when converting older settings
- Fixed Set IA action "prev" and "next" special values
-OR-
