overdrive59
The Mini Effect Gizmo manual states:
"Out – This is the passive output from the Mini Effect Gizmo. This jack is directly connected to the output of loop 5, with no circuitry in between. You can use both the Out and CS Out jacks simultaneously if desired. For example, you can plug the CS Out jack into your amp and the Out jack into a tuner. "
If I were to do this, how would I mute my signal for tuning with out manually turning down amp volume or selecting standby? Looking for implementing tuner mode via Mastermind LT without using a loop on the tuner.
