Hey, all.
I've noticed that the MIDI clock on my PBC will drift when set next to other independent metronomes or MIDI clocks even when I keep it on the same preset. For example, I send it through a Molten Voltage G-Quencer (effectively a sequencer), and my MIDI clock and sequence will drift from my drummer's MIDI clock (he is using a Roland SPD-SX). The same effect happens when I start the metronome app on my iPhone. If I send my MIDI clock to my Hologram Electronics Dream Sequence the same thing happens.
These effects differ from pedal to pedal. The G-Quencer seems to drift a lot faster than the Dream Sequence. And the G-Quencer will drift faster or slower depending on which sequence I am using (probably the shorter sequences drift faster than the longer ones).
Have any of you experienced this? I understand that if I change presets it will effect the MIDI clock because the PBC operating system can't push both at the same time without effecting the MIDI clock. But considering that I am staying on the same preset the whole time what can account for this? Is MIDI clock just a very unreliable timing source? Or is there a programming issue with the PBC? I noticed that if I set the BPM to 116.9 on the PBC when the actual tempo is 117 it will stay in time for a longer period, though it doesn't sound quite right still.
