I was reading in the preliminary manual about setting up the function button as a tap tempo via midi clock. What is the range in milliseconds of the times you can tap.
I was checking out a Molton voltage tempode and its minimum was 250ms which is not quick enough for a couple of my möbius presets but the LBC is fast enough thanks
I have successfully set up tap tempo to my Timeline using the function switch. My issue is that i am seeing for example 130bpm on the PBC but 129.3bpm on the Timeline. I'm assuming i'm doing something wrong? Or perhaps it's the fact that it doesn't have tap averaging but the timeline does?
