seattleguitarist
I posted this as a response to the subject - Re: midi tempo sync is off? - Miracle
I thought it may be worth posting as a new topic though just in case somebody else is experiencing a similar situation.
The strangest thing (or maybe not), i had my mini amp gizmo and marshall jvm on the same midi channel. I was running into an issue with the CC information not being seen properly on preset change even though i had everything set up correctly. I decided i would try changing the midi channel of the amp gizmo to see if that would correct the issue. IT DID! But the real amazement happened when i tried the tap tempo..... It is suddenly spot on. I am running the mastermind gt22 as master midi clock into my axe fx and a tc nova system. They are both dead on. I'm not sure how this happened but it is working.
