Andy Power
ah, then this has been my problem…I tried the MIDI din to ethernet from the out of the Axe then converting it back to a MIDI din on the PPA end, but the GT-16 stopped working…when using a single MIDI cable from the Axe out to the PPA the GT works as it should…but I don’t want to be using a cable like this as I’m wanting the backs of the racks closed up and using midi patch cables to connect the top rack to the bottom rack…If you do the first one, you need two cables between the racks, one specifically from the output of the Axe-Fx to the input of the phantom power box, no other devices in between. With two cables, it should work even with 3 pin MIDI cables. Conversely, even properly wired 5 pin cables will not work in example #1 if you try to use only one cable. There are basically no MIDI devices (except a few of ours) that will pass a bidirectional MIDI signal, so there must be a direct connection from the Axe-Fx MIDI output to the phantom power box. Any device in between will stop the signal from traveling
I took one of my midi cables apart and it has 5 pins connected..so I will solder this to a 5 pin Din chassis panel mount and do the same on the other end connecting to the PPA then I should be able to use a short midi cable to patch (as long as it’s got a 5 pins connected) unfortunately this forum doesn’t allow me to upload photos from iPhone etc so I can’t show you exactly how it is :-(
