Mini Amp Gizmo and MidiMate?
fredster
Hey all,
Can the Mini power a Rocktron MidiMate? The MidiMate requires 9V 2000mA, and the Mini manual states the maximum input current is 9V 850mA. No go?
I can't imagine the MIDIMate actually takes 2000mA - the All Access only uses about 900mA but it says it needs the same current. If the Amp Gizmo's PSU isn't powerful enough for it, use the MIDIMate PSU instead. Should be fine.
Rocktron includes the same 2000mA supply with many of their products. The MIDIMate actually draws about 400mA. (Martin's right, you can use the Rocktron supply to power the Mini Amp Gizmo, but it would be overkill with a Mini Amp Gizmo and MIDIMate - the big supply comes in handy when powering something like the All Access, though).
