Mini amp Gizmo - can this be done
ZeeW
Just a very quick question.... can you operate two mini amp gizmos together... sort of daisy chain them in any way?
Yes, you can chain them by connecting the MIDI Thru of one to the MIDI Input of the other. (You can chain more than two this way, but once you get to four (!) you'll probably want a MIDI Thru box.)
Connected together, you still program each one the same way.
benbutterworth said:
Is it possible to do the same thing with the Mini Effect Gizmo - if so, how do you connect the guitar signal between units?
Thanks
Output of MEG 1 > Input of MEG 2. Just a patch cable. It's that simple :)
