Productrock
I've searched far and wide for an answer to this question. Since you guys seem to be the most helpful, I figured I'd give it a shot.
I haven't bought the Mini Amp Gizmo but I plan to because it's a great solution to "tap dancing" and seems like the finishing touch to my rig.
QUESTION: Is the mute function on the Marshall TSL midi controllable? I've contacted marshall, a few other forums but cannot find solid evidence on whether it is or isn't.
Why do I ask that question? I'm glad you asked lol
For effects I run a line 6 M13 stompbox modeler through the FX loop which is great, love it. The Problem when you use the onboard tuner it's supposed to mute everything (because we all know... who in their right mind wants people to hear them tune a guitar) and it doesn't. A small yet undesirable amount of my guitar comes through.
1. No it's not the line 6, on a solid state marshall it works fine and completely mutes the signal going through the fx loop.
2. Yes my "wet/dry" mix knob is at 100% wet/fx
my only solution at this point while still using the onboard tuner is to run over to the amp and hit the mute button and then tune. So if the mute function was midicontrollable... the mini amp gizmo could control it correct?
Any other suggestions to this problem would be helpful, I know this wasn't the greatest spot to put the question but like I said this seems like a top notch company and I figured you guys or some of people on the forums might have some suggestions.
Thanks so much,
Charlie
http://www.facebook.com/productrock
Thanks so much,
Charlie
