MMGT weirdness
toasterdude
I recently added a second POD to my rig/rack. POD HD Pro X. When i go to edit preset to assign a PC to the Pro X as I use the + and - buttons to select the preset on POD, it updates. Same if I change banks from within edit preset. I set the preset to correct Pod HD X patch and exit edit mode.
I manually move off correct preset on Pod, then when I select the edited preset on GT, my axe and older POD both change to apropriate patches, but the newly edited one, does not change from the preset I selected manually?
This may have to do with the "Send Redundant PC" setting - the GT isn't sending the same program change message because it's already done that (and has know way of knowing that you manually changed the preset on the POD). Can you check that setting on the GT and see if changing it fixes the problem?
