MSB/LSB values...
Rob Leishman
I'm struggling to understand/make work a bank select for the Yamaha multi12 drum pad. The midi implementation for the unit needs a msb message of 0 v125and LSB message of 32 v1 to allow selection of the user banks...
Is it possible to edit msb/LSB messages on the mastermind lt? Or am I missing something completely.
I am able to select specific user bank by sending a cc0 value 125 then a cc32 value 1 then a pg(program number). This works fine but I really want to use bank+ and bank- functions with this unit.
Help me obiRonKenobi you're my only hope!
It seems like you should send the hardcoded values you listed above to get you into the user bank, then you can use preset + and preset - buttons to step through the presets in the bank. You shouldn't need to send CC0 and CC32 every time you select a preset.
