is9582
Hello all,
I haven’t been able to locate documentation regarding the necessary syntax when entering multiple Actions into a single button press (or hold). For instance, if I have a button assigned to turn a Chorus block on or off, but also want to add another Action to turn off a delay block, from the single button press. Would this require one of the System/ selections, in between the two Action, or is it fine to just have the two Action lines? The only time I’ve used a multi-line entry, was to set up the selection for channels in a block, where it used the System/Step in between. I know I can use scenes on my AF3 to accomplish changing multiple things at the same time, but I’d like to know other methods as well as the associated syntax.
Much appreciated!
Lee
Much appreciated!
Lee
