schaefermusic
I have three MEGXs and a Mastermind GT/22. I am trying to get them all set-up together. WARNING: I will most likely have a slew of questions forthcoming and try to keep them a little at a time.
1. If I am using the MGGTEditor (v4.9.1) do I need to use the Mini Effect Gizmo X Editor?
2. If I am needing to use the MEGX Editor, do I need to connect all three simultaneously to the computer? Can I connect one to the computer and daisy chain the other two to the first MEGX?
3. MGGTEditor
a. Under Devices - I set-up MEGX1, 2, 3. Is there anything else I need to do so the MM sees all three of the MEGXs? Does each MEGX have to be on a different MIDI channel?
b. When watching "Mastering the Mastermind" Ep5 it showed an Audio Tab at the top. I am not seeing that as an option. What to do?
c. Under the Preset TAB there is no Audio option as well, nor a place to select Loops for each MEGX. What to do?
4. MMGT
a. I have added the three MEGs under devices. Anything else that needs to be done?
Thanks in advance for any help.
3. MGGTEditor
4. MMGT
