Multiple midi outputs on the GT22
Roy Beukers
Hi guys,
I'm having 2 devices on my board with only a midi in, and the other devices are in my rack wich it connected over the 6-pin XLR. Is it possible to use the midi out DIN at the same time? And even the midi output in the 'XLR Remote in'?
If possible, does this give grounding issues?
Roy
The MIDI Out jack, as well as the XLR MIDI out and pins 3 and 4 on the XLR In jack are all individually buffered, so they would be safe to use simultaneously. In the MIDI spec, the receiving device is responsible for ground isolation, so whether or not you have a ground loop depends on what you're connecting to, and how it's designed.
