Mute button programming, polytune in loop 6
mmattheww
I have a tc electronics polytune receiving the send of loop 6, but no return.
Can I set the pbc’s mute button to mute the output like normal but also enable loop 6 so my polytune gets signal?
I’m using output A and B so using output B is not an option for me.
Actually, you can, you just have to replace the built in mute button with a custom IA button instead. The built in mute turns off the dry signal, which as JimGtr points out mut s the signal at the input. But if you turn off both outputs instead, it mutes at the end. Create a button that enables loop 6, turns off output A and turns off output B. Works like a charm for me!
