need help setting up trails
benny fritz
say for example I have a preset with delay on loop 10 and want trails when I switch to a different preset. what do I do on each preset ?? there is something im not getting so please take me through it step by step....thanks.. the more detail the better !!!!
This is what you need:
- Set your pedal to 100% wet (or turn on the "kill dry" setting if it has one)
- Set loop 10 to parallel
- Turn on trails for loop 10
- If needed, turn on trails in the pedal itself
That should do the trick.
The kill dry of the pbc do the same?
It's similar, but not the same. Kill Dry in the pedal will make it so that no dry signal comes out of the pedal. Turning off the dry signal in the PBC makes it so that no dry signal comes through the mixer. In a parallel effect system with multiple effects, you want only 1 copy of the dry signal to come through, otherwise you will get an unwanted volume boost. The best way to do this is to turn off the dry signal in all pedals, and turn on the dry signal in the PBC.
