backtorack
First of all, I´m new to that rack stuff, so please bear with me if I ask a few noob questions…
OK, I want to setup a stereo rack system using two heads and a few effects (some of them pre, some post amp). The whole rig will be controlled by a MIDI board (not yet sure which one I need).
It´s kinda hard for me to explain what I want, so the following should be possible:
- the amps are a Bogner Ecstasy Classic and a Soldano SLO100, each connected to their respective 4x12” cab running dry at all times when the respective amp is selected
- I do not want to use an effects loop at all
- I do not want to use the Bogner and Soldano footswitch anymore
- the signals that go to the fx rack will be the Line Out from the Bogner and the Slave out from the Soldano
- the selected channel will of course run dry through its 4x12”, but in addition through a stereo fx rack that allows to switch between:
- mono: compressor (pre amp)
- mono: rack eq (pre amp)
- mono: Yamaha SPX90 (pre amp)
- stereo: chorus using two pedals in series (post amp)
- stereo: Lexicon PCM81 (post amp)
- a mixer should be used to preserve a dry signal at all times (?)
- from the mixer I´m going into a MOSFET poweramp into two cabs. So the above mentioned post amp effects (chorus and PCM81) are running stereo.
- I want the midi controller to be able to switch between SLO crunch, SLO lead (SLO uses a standard ¼ cable to switch channels), Bogner green, Bogner blue, Bogner blue boosted, Bogner red, Bogner red boosted (Bogner uses a custom cable to switch the channels and boosts) in any combination (both would be cool if possible), compressor on/off, EQ on/off, SPX90 on/off, Chorus on/off, PCM81 on/off. In addition, it should be possible to control a few things in the PCM81 using CCs (delay on/off, reverb on/off and so on).
- a volume pedal for silent tuning and controlling long/short delays, reverbs and so on
- a rack tuner will be used, but completely out of the signal chain (tuner out from a Gizmo)
- a Furman power conditioner will be used to power each device
So basically, I will have two amps with two cabs and a stereo rack with two more cabs. The Soldano tones are running through the Soldano 4x12” and the stereo rack, the Bogner tones through the Bogner 4x12 and the stereo rack.
I think I will have to use the Rack Gizmo as I don´t need many loops (comp + eq + spx90 = 3 mono loops, chorus + PCM81 = 2 stereo loops, 5 total). Plus it already has two jacks for amp control and I need one (plus the custom cable) for the XTC. I´ve tried to put down a wiring diagram more than once, but have trouble each time.
This https://www.rjmmusic.com/wiring/RG/RG_4 ... _2Amps.pdf is interesting, but it uses the fx loops.
Questions:
- how do I hook up the whole thing and what do I need?
- which product can be used for an isolation transformer that I will need?
- do I really need a mixer as each amp is already running dry on its own cab when selected?
- which midi controller would you recommend and why?
Anything else I could optimize? Right now, I´m still in the planning stage, so I don´t have the rack equipment yet. Are there any changes necessary?
Thanks a lot for taking the time to read this and help me. It´s greatly appreciated!
Questions:
