New LT owner questions
Discussion in 'LT General Discussion' started by ARMANDO DIAZ, Jul 15, 2020.
  1. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    Ok thanks for that info!
  2. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    I’ve got Preset 1, 2 and 3 setup and working so far.
    I would like to save an Alternate 2nd Press to the three Presets. I went into Set Up Mode to set “2nd Press” to Alternate and set the color to “Red”. When I press a saved Preset a second time nothing happens. I was expecting to see the led on LT turn from blue to red but that didn’t happen. I also expected to physically see a PC message on the device but nada.
    Am I missing a step? Didn’t see any additional info in manual. Thanks !!
  3. rjmmusic
    Staff Member
    Jan 18, 2010
    6,519
    1,181
    Did you set the alternate preset number for each of presets 1-3?
  4. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    No. How is that done?
  5. rjmmusic
    Staff Member
    Jan 18, 2010
    6,519
    1,181
    In the Presets tab, just to the right of the Name box and Local Page checkbox, there's an Alt Preset box - type in the number of the preset that should be the alternate for the current preset.
  6. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    Thanks! Is there a way to do this manually in the LT’s setup? Also, when in Alternate Preset, will the PC number be different from from original Preset PC number? Thanks!!
  7. rjmmusic
    Staff Member
    Jan 18, 2010
    6,519
    1,181
    There's an "Alt Preset" setting for each preset in the Edit Presets menu.
    Selecting the alternate preset will send any PCs that are specified in that alternate preset.
    For example, if you have preset 1 and its alternate is preset 101, pressing the first preset button will send preset 1's PCs. Pressing it a second time will send preset 101's PCs. Pressing it a third time will send preset 1's PCs again.
  8. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    Thanks! I tried both methods and found the Editor much quicker. Question; say I select Preset 2 and then select the Alternate Preset on 2 which in my case is 11; how can I select Preset 1 directly after Alternate Preset 11 without having to bank down? Thanks again!
  9. rjmmusic
    Staff Member
    Jan 18, 2010
    6,519
    1,181
    The bank selection remains the same, so button 1 still will select preset 1, even when you're in the alternate preset.
  10. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    Thats not what happened on my end. Selecting Alternate Preset(011) on button 2 then selecting button 1(001) shows as Preset 010 not 001.
  11. rjmmusic
    Staff Member
    Jan 18, 2010
    6,519
    1,181
    Ok, I'll investigate.
  12. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    No need. I’m trying it today and all is functioning as it’s supposed to. I wonder if something is not saving right as I go through the process? Let me ask you, when you have the Rack Gizmo, which has it’s “Write” feature and the LT which has its “Stored” feature and the Mastermind Editor which has it’s “Saved” or “Saved As” feature as well as “Write Changes to Device” feature running at the same time, do I need to save on every device or can saving say from the Editor take care of this all? Maybe “Writing Changes to Device” as well as Save in the Editor? What’s the best way under these circumstances? Thanks!!
  13. rjmmusic
    Staff Member
    Jan 18, 2010
    6,519
    1,181
    Saving to the disk and Write Changes to Device are two separate things - you have to do both if you want to save a copy of your settings to computer as well as transfer settings to the LT.
    Using the Rack Gizmo's Write button vs the LT's IA Store button is a different story. Which one you should use depends on the answer to this question: do you have IA buttons on the LT that control each individual Rack Gizmo loops and switch (at least the ones you're using)? If so, you should never use the Rack Gizmo's Write button, it won't have any effect. Use the IA buttons on the LT and IA Store to select Rack Gizmo loops and switches instead.
  14. ARMANDO DIAZ
    ARMANDO DIAZ
    Aug 16, 2019
    36
    0
    Thanks for clearing that up!
Share This Page
