jluparello
So my PBC 10 arrived just before the holidays. After I placed my order I went right to work in the Mastermind Editor so once everything was setup I could load my settings and go. I got everything hooked up last night and messed around with a few presets but mostly with the individual loops just to make sure everything was routing and working as expected. I loaded my settings over USB and found a few mistakes in my programming. I corrected the settings last night in the editor and went to bed. I'm just getting around to the updates now and as soon as I plugged in the USB the whole system started blinking and pulsing. See the attached video. It's been doing it intermittently for the last 15 minutes. I don't know what to do and I would hate for this to happen in the middle of rehearsal or a show. My setup is pretty straightforward. 6 pedals to the front of the amp, 2 to the amp's effects loop. Everything in mono. I'm running two P+2 power supplies to split the load. When it first started I thought that perhaps something was drawing too much from a single power supply so I started unplugging things to find the culprit. Even with the PBC being the only thing getting power it still behaved the same. Not sure where to go from here!
